-   -   ladder bar rear rodends????? (https://www.racingjunk.com/forums/showthread.php?t=27655)
etchison 03-22-2010 05:36 PM
i posted a tread the other day about my rearend got some good advice, so guys i could use some more. car currently has 3/4x3/4 heims in the front and 3/4x5/8 soild in the rear. its a older A.R.T. set-up. preseason maintence i want to change everything to good 4130 chrome moly rodends. is it good idea to up size to 3/4x3/4 all 6? can i just drill the rearend housing to 3/4? car weighs 2615 and runs 8.90-9.00. also ordered a new track locater bar thats going to be 7/8 chrome moly with 7/16x 7/16 left and rights. is that bigger enough? thanks mike
curtisreed 03-23-2010 04:13 AM
A 3/4" shank x 5/8" hole 4130 XM seriers rod end from Aurora is rated at 40,572 lbs and the 3/4" x 3/4" is rated at 28,081 lbs static load so I wouldn't change the size in the rear.
Curtis
etchison 03-23-2010 05:21 AM
Curtis
thanks thats good to know. but it is a good idea to change them to heim, right? also all 6 threads are righthand is this normal? thanks mike
oldandtired 03-23-2010 06:46 AM
Drilling out 5/8 to 3/4 is not an easy task. Doorracer is right on...
JMO. Dave
ccperf721p 03-23-2010 07:11 AM
There really is no need for heim ends on a ladder bar. I prefer to use a solid rod end all the way around myself. More moving parts equals more points of possible failure in my eyes.
etchison 03-23-2010 11:32 AM
well i ordered the solid 3/4x5/8 for the rear and 3/4x3/4 4130 heims for the front from rick jones. thanks guys for all the help. mike
curtisreed 03-23-2010 12:03 PM
If your bars don't have them it is a good idea to add the safety loops on the front ends.
Curtis
wmeabates 03-23-2010 03:25 PM
If you use a panhard bar, himes front and back will free up the up and down movement some because the housing needs side to side movement as it moves up and down.If you use a bar between the ladder bars you only need himes on the front.solids on the front will bind up and down movement.Bill.
etchison 03-23-2010 05:45 PM
thanks wmeabates i'm using a track locater so i should be fine
