-   -   TORQUE SPECS (https://www.racingjunk.com/forums/showthread.php?t=27685)
JEFF69Z28 03-26-2010 10:28 AM
TORQUE SPECS
What should i torque the bolts to on my monte carlo front upper and lower control arms to?also what should the ball joints on the above be torqued to?
FullTimeRacing 03-26-2010 11:56 AM
I have never put a torque wrench on those type of parts.I hit the lowers with a impack and the uppers with a wrench,with the weight of the car on then tighten.also tighten the balljoints with a wrench.line up the hole for the kotter pin.
JEFF69Z28 03-27-2010 03:58 AM
I PUT TUBULAR UPPER AND LOWERS ON.I SHOULD LOOSEN THE NUTS PUT THE TIRES BACK ON LOWER IT THEN RETIGHTEN.
THANKS FOR THE INFO.
FullTimeRacing 03-29-2010 09:24 AM
yes
