-   -   no spark (https://www.racingjunk.com/forums/showthread.php?t=27701)
alleyk 03-28-2010 11:54 AM
no spark
have msd 7al3 and crank trigger every time a throw my painless ignition switch i blow a fuse what could this be
TS1955 03-28-2010 04:24 PM
Sounds to me you have a dead short somewhere. But the first thing that I would do is make sure everything is wired correctly. Then the best thing to do is get a volt/ohm meter and go through the process of elimination. Check your switch, check wiring making sure you don't have a bare wire. JMO.
TS1955
TheYellaBrick 03-28-2010 07:44 PM
Have you used this system prior to this ?
Is this a brand new system and this is the first you've put juice to it ?
