-   -   ladder bar adjustments (https://www.racingjunk.com/forums/showthread.php?t=27720)
nova77 03-29-2010 07:40 PM
i am playing with my ladder bar settings. i am currently set in the middle hole and my shocks are set as loose as possible. what happens if i move a hole up are a hole down. I have read that moving up makes the tires hit harder. does this improve traction ???
Car weighs 3300 lbs and runs 9.70. runs 1.39 60' spinning the tires.
ccperf721p 04-25-2010 10:04 AM
Contrary to popular belief, setting the shock looser hits the tire softer. Try tightening up on the shocks first, if it still doesn't hook go up with the ladder bar.
Tod74 04-25-2010 11:40 AM
Raising the bar up will hit the tires harder...if it isn't hooking,why would you hit the tires harder? Just asking.
