trailer black streak remover
Has anyone used any of the black streak removers??.. My white trailer is in need of a wash. What brand did u use and was there alot of elbow grease needed??
Thanks Keith |
I have used simple green, works great without alot of elbow grease and its not that expensive.
walmart says black streak remover with the motorhome stuff, it works great.
Also see a lot of people using Awesome from the dollar stores. but for sure if you use it dont let it sit to long it eats the alum. |
LA Awesome at Dollar General. Cheap, works great.
DISCLAIMER-Try a test spot of anything anybody recommends before doing the whole trailer. |
Here in the south everything mildews or rust. The north side of the house mildew forms on the vynil siding and on the north side of the trailer.
Redneck solution, 1/2 gal bleach, 1 gal. water, a couple onces of dish washing deterget. Put in a pump up garden sprayer, and spay down the trailer, about 6' at a time, tuffer stains use a kitchen spunge mop. Then hose it off. Sometimes requires 2 applications, but removes rust stains and black streaks. Zip. 15 yr. old Haulmark trailer before http://img.photobucket.com/albums/v5...2/100_0867.jpg after, no mop used just spray on and hosed off, would be better if i used a mop. http://img.photobucket.com/albums/v5...2/100_0871.jpg |
This topic comes up alot. I've used alot of so called remedies but what I found that has worked for me the best is some stuff called RV-455 I got it from a fellow racer Dave Ribeiro his e-mail address is [email protected] or you can call him at 757/810-1832. Tell him you got his name from me, Vince Tosto.
His stuff works great. I'm sure other guys have some great stuff too but this product worked for me. Beleive me I used alot of different stuff. |
Sorry for repeating myself, but the proof is in the pudding
First let me say, that is my fault for the insides getting this way. I didn't use the trailer in all of 2009, i used my open trailer only going 35 miles too the track, plus i knew i had to replace the drop down door wood. With 100 degree temperatures and 70% humidity, it made a builtin fungus bearing hot house. With that said, i was still surprised at how bad it got by leaving it shut up for over a year. So i replaced the door wood and i'm now cleaning the interior. The movie speaks a 1000 words.
Zip. Now you see it http://img.photobucket.com/albums/v5...2/100_0904.jpg When people are in doubt, nothing proves it like a video, so i made one. The vid says a 1000 words. Click on img for the video http://img.photobucket.com/albums/v5...h_100_0905.jpg Now you don't after 10 minutes of cleaning http://img.photobucket.com/albums/v5...2/100_0907.jpg |
| All times are GMT -8. The time now is 08:56 PM. |
