CLEARANCE -73 Challenger w/ALTERKTION & MILODON Oil Pump
Anyone experienced CLEARANCE PROBLEMS using the MILODON H/V ALUMINUM OIL PUMP in a 73 Challenger with 572 HEMI and the AlterKtion Coil-Over Front End set-up?
I've been told that I may have clearance problems with the driver's side motor mount when using this oil pump and might have to change the mount set-up. If anyone has used this combination in a Challenger please let me know. THANKS, Scott in Michigan. |
oil pump clearance problem on 73 challenger
Had that problem before on a regular front end . Installed a front motor plate and then it all fits fine. This was for a drag race only application, not recommended for street use.
| All times are GMT -8. The time now is 09:03 AM. |
