running 8:70 in the 1320
how much hp do i need in a 2900 lb car to run 870s?
Your HP computed from your vehicle ET is 783.38 rear wheel HP and 870.42 flywheel HP
Zip. |
Hey Zip, What will my 2350 lb car run with 875hp at the flywheel. Thanks, Mike
Zip. |
Zip. |
Zip. Thanks Chris |
Zip. Thanks Chris Your ET / MPH computed from your vehicle weight of 2165 pounds and HP of 767 is 8.23 seconds and MPH of 162.75 MPH. |
Zip. Thanks Chris Your ET / MPH computed from your vehicle weight of 2165 pounds and HP of 767 is 8.23 seconds and MPH of 162.75 MPH. I will make sure I bring a couple pairs of shorts to change into. The gentlemen that had it before me was running some 8.40's with it. I will be glad to finally get it out to the track. I am redoing the wiring and cleaning up the engine bay before I install the new 418 sbc I got for it. I will keep yall informed. Chris |
8.10 wow
Thanks Zip, Hey Chris I got ya covered By a Tenth. Mike
Re: 8.10 wow
Chris |
Re: 8.10 wow
And both need diapers.
quote="bowtie4542001"]
Chris[/quote] |
| All times are GMT -8. The time now is 08:07 AM. |
