-   -   95 mustang 50 high oil pressure? its always on the a in norm (https://www.racingjunk.com/forums/showthread.php?t=27792)
bizzarro 04-08-2010 12:57 PM
ihave a 1995 mustang 5.o and the oil pressure is always around the a in normal is this high ? should i be concerned or what does this mean? thanks
TheYellaBrick 04-08-2010 05:55 PM
Install a real gauge and sender unit for an accurate reading and THEN ask this question. Idiot lights and word gauges are garbage. I want to see NUMBERS.
bizzarro 04-09-2010 09:17 AM
what brand of gauge?
what brand of gauge u reccomend and do these come together?
TheYellaBrick 04-09-2010 06:51 PM
Anything from Jegs or Summit
cepx111 04-09-2010 09:56 PM
Re: what brand of gauge?
I only use Autometer, they make some accurate & quality gauges.
I'd buy the three 2 1/2 inch gauge set-up, water temp, oil pressure, voltmeter, AND a BIG low oil pressure warning light in your FACE and you'd be set.
I used a old shift light I had laying around and changed the color of the lens, bought a low oil pressure sending unit form parts house (one wire) it was for a 78 oldsmobile W/ rocket 350..lol
Cp
