-   Tuning & Diagnostics (https://www.racingjunk.com/forums/forumdisplay.php?f=22)
-   -   what plugs and gap (https://www.racingjunk.com/forums/showthread.php?t=27800)
hotrodharley 04-09-2010 07:46 AM
what plugs and gap
building a 540bbc blown alcohol engine
11.8 static comp.
731/726 lift roller //114 lobe center //running dur 322--326//dur at .050 284--288
brodix heads flowed to 372cfm on intake at 700 lift
12-71 blower 20%OD
big&ugly injector hat
port nozzles
110 pump
mallory supermag111
trans;;pg with brake
1;80 straight cut gears
10 disc high gear
4;30 gears
car estimated at 2800 lbs
32x14.5x15 slicks
what plugs and what should i gap them at to do my first start-up?
what hp do you think i'll be at?
zipper06 04-16-2010 08:17 PM
NGK 9's .025 gap
bbchevy 04-17-2010 08:46 AM
Re: what plugs and gap
11.8 static comp.
12-71 blower 20%OD
port nozzles
110 pump
mallory supermag111
10 disc high gear
4;30 gears
32x14.5x15 slicks
1500-1600HP Give or..............?
Later '
G 8)
