-   -   roll cage question (https://www.racingjunk.com/forums/showthread.php?t=27805)
chevysteve2 04-09-2010 10:11 PM
roll cage question
I am putting in a jester 10 point cage in my wifes nova. the seatbelt bar and the two (short) down riggers that attach the front suspension mount to to the seatbelt bar and main hoop, are 1 1/4 inch. the main hoop and all the other bars are 1 5/8. I called jegs and they said the bars are legal for competition. Just want to make sure before I weld them in place. because the cage in my car has all the same diameter bars.
cam67152 04-10-2010 08:19 AM
Yes 1 1/4" is all that is required for those bars, min. thickness must be .065" CM or .118 MS.
Good luck with the install :D
cam67152
chevysteve2 04-10-2010 08:29 AM
thanks for the quick response, I will weld it in
