-   -   Retarding the timing on blown engine (https://www.racingjunk.com/forums/showthread.php?t=27825)
jreiley 04-12-2010 08:30 AM
How much timing should the ignition be retarded on a blown bbc per pound of boost? Or should it?
herbtfx 04-12-2010 10:12 PM
Blown BBC Timing
Assuming that you are using a mag (locked, no advance), set your total timing within your tuning window and leave it alone.
zipper06 04-14-2010 07:30 PM
It totally depends on the engine, blown alcohol usually likes around 32*, if you lay a little nitro on it it needs to be down to 28*'s and even lower depending on how much nitro.
just from my experience
jreiley 04-16-2010 03:11 AM
The car is just your run of the mill 67Camaro. Gas. Distributor and msd 7
zipper06 04-16-2010 06:58 AM
A freind of mine runs a 871 on a 383 small block. He has it set at 32* with an automatic 4* retard at 8lbs. It's 4500 lb shortbed chevy and street driven, but runs in the 11's in the qtr. mile. I don't know how he has it wired up, but he also uses a MSD.
hope this helps
