-   -   2001 silverdo 5.3 (https://www.racingjunk.com/forums/showthread.php?t=27875)
Swiley383 04-20-2010 09:06 AM
2001 silverdo 5.3
2001 silverdo 5.3 Just replaced both head gaskets due to leak. Now is really hard to start.engine Motor spins over fine it acts like a fuel related problem. New filter did not help and now the service engine light is on. There is a problem with the port for the scan tool it will not connect to the computer. I am out of ideas any suggestions?
johnracer 04-20-2010 10:37 AM
Check the cig lighter fuse. If it's blown, scanner won't communicate with the ecm. Will it finally start? Have you checked the fuel pressure?
Johnny
Swiley383 04-20-2010 11:34 AM
I will check the fuse tonite. I have not checked the fuel pressure yet but that will my next step.
Thanks, for the help
Swiley383 04-20-2010 11:36 AM
Yes it will start it just take a lot of cranking
Swiley383 04-21-2010 04:59 AM
The lighter fuse was blown and the scanner showed a code for the cam shaft position sensor. I fixed the problem last night and it cranks and runs great thanks for the advice.
johnracer 04-21-2010 05:09 AM
No worries, glad I could help!
Later,
Johnny
