-   -   DOMINATOR RECCOMENDATION (https://www.racingjunk.com/forums/showthread.php?t=27879)
ssmonte70 04-20-2010 05:13 PM
I HAVE A 540 PUMP GAS MOTOR 10.5 COMPRESSION GRUMPY JENKINS ALUM MERLIN HEADS, ROLLER CAM DURATION @50 INTAKE 275, EXHAUST 286, LIFT 746 INTAKE 751 EXHAUST, TURBO 400 10" CONVERTER 3800 STAHL,WOULD LIKE TO KNOW WHAT CARB TO USE, HOLLEY ULTRA 1050, OR THE QUICK FUEL, 2OR 3 CIRCUIT, OR OTHER BRANDS, THE CAR WILL BE ON THE STREET 90% OF THE TIME, THANKS
TS1955 04-21-2010 05:11 AM
As far as the carb goes I would probably go with a Holley 1050. But my concern on this combo is that it looks like it has a little too much cam for a 10.5 compression motor. With a cam that big, your dynamic or running compression is going to be from 7.5 to about 8 to 1. This depends on when your intake valve closes. JMO
TS1955
ssmonte70 04-21-2010 11:42 AM
dominator reccomendation
TS1955
i know the cam is to big at the time thats the only cam i had, on the carb should i use a 2 or 3 circuit, and the holley is better than the quick fuel, what size cam would be good, thanks
jmarksdragster 04-23-2010 10:04 PM
If it were mine I'd get the Ultra 7320, 2 circuit 1150. Your engine will be much happier.
markdunlap 04-25-2010 06:01 AM
Dopminator recommendation
I own a 1050 Ultra and it is very coinsistant on a 496 BBC bracket engine. If you are using it on the street I would consider having a carb custom built to get it right for you. Pro Systems would be my choice. I have an old Pro Systems 1050 also and it is just as good as the Ultra, just not as pretty.
russ67chevelle 07-13-2010 10:04 PM
think of your cam this way...if it was smaller and made more torque, could u use it on the street???
