-   -   383 stroker (https://www.racingjunk.com/forums/showthread.php?t=27898)
RobertO58 04-23-2010 11:34 AM
383 stroker
I have a 383 stroker in a 68 camaro that when accelerate from 1000-2500 rpms with or without a load on it will back fire throught the carb does not make any difference what kind of carb does the same with a holley or edlebrock 26 total timing
TheYellaBrick 04-23-2010 05:00 PM
Is this street-street/strip - or strip only car ?
At what point of acceleration does this happen ?
If it's just as you stab it, it could be not enough accel pump volume, even on 2 different carbs, it could be weak or not enough. Also could be your advance is not working or is gummed up within the distributor.
zipper06 04-23-2010 06:56 PM
26* is not enough timming even for a stock engine, should be 32*/36* total timing.
cepx111 04-23-2010 10:25 PM
X2
I'm pretty sure my lawn mower has more timing than that!
Double check your firing order too.
cncmotorsports 04-27-2010 07:22 PM
Needs more timing
et7333 04-28-2010 09:56 AM
x4
RobertO58 05-06-2010 03:59 AM
when I put more 32-36 in it it diesels when i try shut it off and i still get a back fire through carb, also when i remove vacum advance hose the motor dies,
bowhay 05-06-2010 04:36 AM
check for vacume leaks
Scooterz 05-06-2010 10:29 AM
Are you sure that you have the correct vacuum source connected to the vac/adv? It may be that you have too much constant/high vacuum to the vac/adv & it is advancing too soon... while not enough timing on motor which maybe is why it dies when you disconnect the vac/adv hose... not sure, just a guess.
kwkracing 05-06-2010 11:41 AM
Sounds like your timing marks are not accurate
