How to id a SBC camshaft? I know, tough
http://i710.photobucket.com/albums/w...B750/camid.jpg
This is a cam I have on an engine I bought. I know it was a mild performance rebuild on a 400 with 5.7 rods and KB pistons. The machine shop that bored the motor also supplied the cam. Guy who had it built thought is was about 512 lift. It could be a house brans special. Kind of a long shot, but can't hurt to ask. Any thoughts on the make or info based on these numbers? |
If nobody would care to speculate, is there a forum you can recommend which might know?
Thanks! |
You can send the camshaft to any camshaft manufacturer and have them cam doctor it, this will tell you exactly what it is.
that's the old 310-2H.
So it sounds like the 310-2H is a Crane Cams grind number. I can't find exact specs.
Thanks for the help so far! |
Part Number: WG1051K Grind Number: 310-2H
Engine Identification: Start Yr. End Yr. Make Cyl Description 1957 1987 CHEVROLET 8 Engine Size Configuration 262-400 C.I. V Valve Setting: Intake .000 Exhaust .000 HOT Lift: Intake @Cam 3439 @Valve 516 All Lifts are based on zero lash and theoretical rocker arm ratios. Exhaust @ Cam 3500 @Valve 525 Rocker Arm Ratio 1.50 Cam Timing: TAPPET @--- Lift: Opens Closes ADV Duration Intake --- --- 310 ° Exhaust --- --- 318 ° Spring Requirements: Triple Dual Outer Inner Part Number --- Loads Closed --- LBS @ --- or --- Open --- LBS @ --- Recommended RPM range with matching components Minimum RPM 3200 Maximum RPM 7000 Valve Float ---- Cam Timing: TAPPET @.050 Lift: Opens Closes Max Lift Duration Intake 20 BTDC 44 ABDC 102 244 ° Exhaust 56 BBDC 16 ATDC 110 252 ° |
| All times are GMT -8. The time now is 02:50 AM. |
