-   -   Rich or lean that is the question (https://www.racingjunk.com/forums/showthread.php?t=27935)
rabbit 04-28-2010 05:57 PM
I got a new car about 2 months ago and it it just starting to get cruising weather(yes a street car). I haven't pulled the plugs yet to try reading them but I was wondering. My car is running rich I think. It runs awesome at full throttle but at idle and cruise it has an awful hesitation, very little low throttle response and it burns your eyes something fierce just to walk behind it. Am I right in thinking rich could this be a very lean condition?
Thanks, Rabbit
I forgot to mention this is a 427 BBC with old school 3 pc Weiand tunnel ram and 2 450 cfm holley carbs.
Tod74 04-28-2010 10:18 PM
Re: Rich or lean that is the question
Thanks, Rabbit
If it burns your eyes it's rich. The tunnel ram needs to go. Probably doesn't have enough air velocity at part throtle low rpm.
oldandtired 04-29-2010 06:42 AM
X2
Dave
TheYellaBrick 04-29-2010 08:29 AM
Probably LEAN as them carbs at such HIGH altitude !!
I'm getting a nose bleed from just LOOKING at his car !!! :shock: :shock: :shock:
LOVE IT !!!
Check it out gang !! :D :D :D :D
http://www.racingjunk.com/profile/40325
Scooterz 04-29-2010 08:53 AM
Amen Double/D!!! Yep, very cool. I have agree w/ Tod on that one. It is rich on the low end/idle circuit... not enough vacuum it is dumping too much fuel.
cepx111 04-29-2010 09:38 PM
IMO< U need 2 things less fuel at an idle and more at part throttle, for the idle circuit, adjust the mixture screws IN till it falls off then back out a 1/4 to a 1/2 turn out, also check float level, if their too high it will make it idle rich too.
With a tunnel ram you dont exactly have alot of signal strength from the motor, so you need to dump a ton fuel in the accelerator pump circuit to over come the sudden rush of air when you open the throttle, I recommend 50cc accelerator pumps on the primaries as I starting point.
TheYellaBrick 04-30-2010 05:42 AM
Over the years I've seen very drivable tunnels on the street and a lot which were totally undrivable. It all depends on the complete engine combination.
rabbit 04-30-2010 10:09 AM
Thanks that is the kind of answers I was looking for. Floats are good just running "fat" down low. I will look at the idle mixtures and then start in with squirters and pumps. I have always sucked at tuning carbs but the looks of the tunnel ram just screams "don't even think about it!".
By the way guys the little Chevy II you talked about is no longer mine, I have a new toy I am working on now.
Thanks everyone, Scott
