383 cylinder scoring? Anybody have any ideas?
I am building a 383 stroker, ran for about 2 hours and started to hear a wierd noise, sounded like pistons slap so i pulled the motor back out and actually found the one of the pistons was dented in on the skirt, Found out somebody had knocked that piston off of the bench and didn't tell me about it, Anyway while I had that head off i noticed the cylinder walls seamed to be scored just a bit, But i had only ran the engine for a few hours all together. Just wondering if anyone would know why it would have scoring already. I have molly pistons. top end gap .018 and bottum end gap .021. 850 carburator, seemed to be running to rich.
Re: 383 cylinder scoring? Anybody have any ideas?
Originally Posted by josh4ku
I am building a 383 stroker, ran for about 2 hours and started to hear a wierd noise, sounded like pistons slap so i pulled the motor back out and actually found the one of the pistons was dented in on the skirt, Found out somebody had knocked that piston off of the bench and didn't tell me about it, Anyway while I had that head off i noticed the cylinder walls seamed to be scored just a bit, But i had only ran the engine for a few hours all together. Just wondering if anyone would know why it would have scoring already. I have molly pistons. top end gap .018 and bottum end gap .021. 850 carburator , seemed to be running to rich.
Did the machine shop have all 8 pistons when they did the machine work?
Metal sloshing in the oil pan gets on the pistons and cylinder walls and scratches them.
Inproperly filed rings also can scar up cylinders. Inproper cyllinder clearance. No lube on cylinders on assembly ??? |
Is this a hyperutectic piston or a forged piston, Mahle makes both. If you bought a rotating assy it's possible that they are hyperutetic's and if that's the case the ring end gap is way too little and could cause scoring of the cylinder walls. Also do you know how much piston to wall clearance you have?
Zip. |
Machine shop
Yes they had all 8 pistons at machine shop, and yes they had lube at assembly, I am pretty sure I have forged pistons but I am going to double check, And I will check what the pistons to cylinder clearance is and get back to you guys. Thanks.
Pistons.
Running to rich.
Can running the engine to rich wash down the cylinder walls enought to cause scoring? The pistons seemed really wet when we pulled the head off.
Zip. What is their hyper piston P/N??? |
Was your block plate honed?? |
| All times are GMT -8. The time now is 07:56 AM. |
