-   -   installing oil accumalator (https://www.racingjunk.com/forums/showthread.php?t=28039)
cburge 05-14-2010 05:00 PM
i have a 90 GT and bought a Moroso oil accumalator,i have never used or installed one,where would u mount it? Also,do you have to drill and tap to plum it on stock oil filters housing or where else could i plum the inlet too?
BEAST477 05-14-2010 06:14 PM
Moroso has an adapter that goes between the filter and the block. I would use the electric solenoid So it prelubes every time you turn on the ignition. I mounted mine to the firewall just below the master cylinder.
