-   -   expozy primer (https://www.racingjunk.com/forums/showthread.php?t=28102)
mmphillips 05-22-2010 05:26 PM
expozy primer
Im doing body work on a 71 nova. the car is in bare except for the new 1/4's.i want to spray ppg expozy on it.should I sand the new 1/4's down to bare metel or keep the coating on,then spray expozy on top of the 1/4's?
Tod74 05-22-2010 07:50 PM
I would bare metal them then epoxy,then do the bodywork on top of the epoxy.
MEMRACING62 05-22-2010 08:37 PM
x2 what tod said. if after you epoxy & it sits more than 3-4 days lightly sand epoxy before body filler or primer is applied over it.
DirkaDirka 05-23-2010 11:08 AM
Ok if you are going to be applying bondo or Plastic filler you should apply it to bare metal that has been ground a little so that it will "stick" or "grab" onto the metal. Sometimes it is a waste of primer applying the bondo or plastic filler after you primer due to having to rough it up so it will stick. As for the new 1/4s you dont need to take them down to bare metal. Just need to rough them up so that the primer will stick to them. Just have to make sure that there is no surface rust starting when you go to primer them. Hope this helps
Tod74 05-23-2010 05:50 PM
No offense Dirka but that is how it was done 20 years ago...I still do that because I don't mess with the epoxy primer since I do not have a booth . I use self etch and 2k Urethane....BUT the general consensus from Professionals now is epoxy first to seal everything then body work on top. EPOXY isn't the same as old school primer.
