Powerglide input shaft
Sorry if this has been asked before. If a glide has been set up for a turbo spline input shaft, can a powerglide spline input shaft be used. Reason I ask is the tranny in my car has a powerglide input shaft. And I also have a tranny with a turbo spline input shaft and was wanting to keep it as a spare. THANKS!
TS1955 |
Yes, you can put a pg spline shaft back in it....
Thanks for the reply!
TS1955 |
the input shafts will interchange but your convertor is only going to work with one of them.
| All times are GMT -8. The time now is 02:02 PM. |
