-   -   how to wire msd crank trigger (https://www.racingjunk.com/forums/showthread.php?t=28208)
greenone60 06-07-2010 07:46 AM
i have a used crank trigger for a sbc.and iam running a mallory unlite dist. and a 6al box. how do you install and set up crank trigger,wiring,phasing the rotor,ect?and do you have to lock out the timing
curtisreed 06-07-2010 08:29 AM
See it this is what you need.
http://www.msdignition.com/instructi...=crank+trigger
Curtis
greenone60 06-07-2010 09:12 PM
that is what i need. thanks for the help
TheRabbit 06-08-2010 05:40 AM
One thing to remember is that on a distributor the wires from your ign. box that plugs into the dis. are swapped. ( Green to Violet). On a crank trigger they match ( Green to Green, Violet to Voilet). The crank trigger should have a plug so it shouldn't be a problem.
hammertime 06-09-2010 06:26 AM
hmmm mine arent swapped ??! Dist is same as the crank trigger
