-   -   need help on pete jackson gear drive (https://www.racingjunk.com/forums/showthread.php?t=28253)
promod45 06-13-2010 12:43 PM
i have a PJ gear drive and no instructions for a customers motor. it has two dots on the big idler gear and a dot on the crank gear and one on the cam gear so there is a total of 4 dots on this gear and when i degree cam in i end up with 132 centerline, so i cold use help if you can thanks
gimmemud 06-15-2010 05:10 AM
Dont worry about the dots, degree the cam where it needs to be.
