-   -   bbc headers 65-67 chevelle (https://www.racingjunk.com/forums/showthread.php?t=28288)
nitrodeath 06-17-2010 10:06 AM
Can any one help me out..I am putting a standard deck bbc in a stock chassis 65 chevelle and I am running canfield 24.5 raised exh port alum heads..I was wondering if I will have header problems due to the 5/8 raised exhaust ports..I want to use hooker super comp 2220 headers...If anyone has any helpful info on this please let me know...thanks
BEAST477 06-17-2010 04:58 PM
Have you tried contacting thier tech dept.? They should be able to tell you.
nitrodeath 06-17-2010 06:27 PM
Hey thanks..I have a e-mail in to hooker but they are lagers...There has to be someone out there using raised port alum heads , dart , brodix , gm ect that has them in a stock front chassis, chevelle , camaro, gto ect....what headers are they using ????
oldandtired 06-18-2010 05:44 AM
You might try Doug's Headers.
They do offer a special design for 2-1/8 dia, full length for tall deck BBC in a 67-69 Camaro or 67-74 Nova
PN 776-D321
I went thru all this with a tall deck and raised heads in a 55 Chevy. After trying 4 sets (and return freight) I had some made. What a pain.....
Dave
cepx111 06-21-2010 10:34 PM
I hate to post this but....
You might try this post on yellowbullet's forum.
Tod74 06-22-2010 12:10 AM
Re: bbc headers 65-67 chevelle
I put Brodix -2x heads on my Nova.They have raised exhaust ports.I had to do some hammer mechanic work to get them to not hit the control arm bushings on the drivers side...they hit with the GM heads already so t have a dent there anyway but had to move the dent........ I also had to notch the trans cross member just a tiny bit (just a small piece of the lip,not the whole crossmember)because my collector on the passenger side just touched it enough to keep me from getting the header up enough to start all the bolts.
My headers are Hooker Super Comp
