-   -   Holley 4150 Rebuild Question (https://www.racingjunk.com/forums/showthread.php?t=28341)
yost51 06-26-2010 12:38 PM
I'm working on a 600 Holley and its my first time going through a rebuild. Everything seemed to go smoothly except for the leftover part that I have. I can't remember where I removed these pieces from and I've went through the carb several times trying to find it. The picture is below. Does anyone have any idea where this goes? Thanks in advance for the help.
http://img193.imageshack.us/img193/5609/028id.th.jpg
fla1976 06-26-2010 12:51 PM
Can't really tell too much from the photo, eyes are not as good as they once were. Here is a site that may help though. Increase the resolution to around 250 for a better view.
http://www.holley.com/data/TechServi...ded%20View.pdf
JimmySmith 06-27-2010 07:44 AM
carb parts
Can't see it very good but on left looks like acc linkage connector, middle goes in metering block and takes the gasket that is rounded and on right don't know. Later J.Smith 4621 racing
yost51 06-29-2010 08:01 PM
From my recollection it all came out together from the same spot. I apologize for the blurry picture. The camera I'm using isn't very good. From left to right there is a check ball, a spring, a nipple type item with no hole, and a plug type item with slots for air or fuel (not sure).
cam67152 06-29-2010 09:26 PM
The ball could come from acouple of places depending on the model....
1.primary fuel bowl, under the accelerator pump.
2.under the pump discharge nozzel.
3.the vaccum canister if it is a vac secondary
I would guess the ball came out of option 1. but just a guess from what I can make out. as for the other parts :?: :?:
JimmySmith 06-30-2010 05:39 PM
With the last description I would withdraw my guess cause it ain't right sorry J.Smith 4621 racing :?
cepx111 06-30-2010 09:40 PM
I'm gonna go with option #2
Hey Jimmy, check your pm's
Cp
