need help with front coil springs
im trying to install my coil springs and control arms on a 80 t/a but everytime i try to jack up the bottom arm the body of the car starts to lift, any suggesions or tricks i could try?
You probably have no motor / trans weight to compress the springs.
Coil spring compressor is the safest way. I have also run a chain around the frame and under a floor jack, jacking against the lower a arm. It's dangerous no matter how you do it. Lots of kinetic energy that would love to jump out and bite you. |
Is there a way you can anchor the body down to the floor to prevent it from lifting??
no theres not, where might i find a coil spring compressor or would i have to order it
If you have an auto part store around they should have tools you can rent.
alrighty then thanks
Look in the yellow pages for a spring place.There is a place in Indy that sells springs and For around $20 they will compress a pair of springs for you and band them together.You just instal everything then reach in with some cutters and cut the band.
i went and got one from the parts store and got it done, thanx for the help guys
FYI, Harbor Freight has a cheap coil spring compressor if you only need to use one every now and then.
ESPECIALLY for this particular job, I would NEVER use a cheap Chinese junk tool. :shock: :shock: :shock: :shock: Good way to loose your head !! Load it on a car trailer and tie it down to so you can use a floor jack under the 'A'arm to compress it. |
| All times are GMT -8. The time now is 06:38 AM. |
