-   -   MSD DIGITAL 7 7530 T (https://www.racingjunk.com/forums/showthread.php?t=28426)
dynaguy03 07-12-2010 04:50 AM
Hello All
I have a dragster with the digital 7.. i hooked up my computer and do not see where i can program it to activate my electric shifter.. Also .. is see most of the outputs can only handle 3amps.
So where do i program the MSD to shift 1 time at a certain RPM.??
Thanks In Advance
TheRabbit 07-12-2010 05:23 AM
I have the same box, but I use the MSD monitor mounted in my truck. Here is the link to MSD so you can go to it and download the instruction sheet.
chevyfireball 09-08-2010 02:13 AM
If you look on the list there is one that says timer switch, rpm switch. Choose which one you want it'll turn off the other one - sounds like the rpm switch, and set that for the revs you want.
I972Nova 09-12-2010 02:15 PM
I set mine to work off the yellow wire which is the shift light in the settings. You can feed the yellow wire to a relay then out to the shifter. The MSD box sends out a ground and the relay comverts it to positive.
Hope this helps...
