-   -   chevette help (https://www.racingjunk.com/forums/showthread.php?t=28458)
ballsout1 07-18-2010 04:15 AM
chevette help
just bought a small block chevette and i`m searching for headers that will fit. i`m hoping something from another vehcle might work. also looking for a lite weight scooped hood....
ballsout1 07-18-2010 04:12 PM
i`m thinking more room for headers if i relocate the master cylinder to the inside of the car on the left and a small starter on the right and a narrowing and reboxing of the front subframe. on the right....i need some input here. i`m gona contact some header manufactuers direct. theres nil for room in there.
bjuice 07-18-2010 04:13 PM
fender well exits.
ballsout1 07-20-2010 04:58 PM
well... i want to run the stock inner fenders, its also the upper shock mount and its structural to the front subframe assembly. if it was a full cage as opposed to my bar set up i could do the shock mounts to the front engine compartment bars... but thats not what i have. idealy i like to have a bigger tube street rod "hugger" header that was actually made for my applcation. anyways thnx for the input.
bjuice 07-20-2010 06:00 PM
don't know about running stock fender wells....but here is my Friends 1977 Honda Civic 555ci alcohol blown injected BBC.....The Vid you are seeing is a 4.69et pass 150mph +.....you should see it when he runs 40%-50% nitro.. :roll:
the civic might even have a little shorter wheel base then your chevette..
Danny has real Big balls driving this car....see the other Vids attached and watch the man drive this car....
http://www.youtube.com/watch?v=mYzKN...eature=related
cam67152 07-20-2010 06:59 PM
Those aren't BIG BALLS those are CO-CO NUTS :shock:
THERATTLER 07-20-2010 07:15 PM
here is my favorite of Danny
http://www.youtube.com/watch?v=YPKc4dvWmdY&NR=1
zipper06 07-20-2010 08:46 PM
Just a guess but the early nova 63/67 may fit the front subframe, there are a few mfg'er of them for under the car, but i think only 1 3/4" max.
