Ford 9" rear end
I just bought a new car and it has a braced ford 9". I would like to know how much rear end dope goes in? Three quarts or ? Thanks
Just fill it to the bottom of the fill plug. When it starts leaking from the fill plug, it is full.
2qts
2qts
LIVELY |
LIVELY |
The fill plug should be on the side of the housing a little higher than the level of the pinion gear. It sounds like you are looking at the pressure vent on the top of the housing.
It's probably a race prepped housing with a fill cap welded on the top and sealed axle bearings. 2 quarts would be plenty.
| All times are GMT -8. The time now is 01:33 AM. |
