recamming the SBC 406 questions
going with an isky hydraulic roller
cam card here. anyone use this cam ? i got 3:93 rear ratio and 2500 stall converter on a built th350. brodix -10 aluminum heads 11:1 compression also I got 150 nitrous shot on the plate. will this cam work ???? thoughts??? http://iskycams.com/ART/iskylogo.gif TIMING CHART PART NUMBER: 211282/294GRIND NUMBER: rr-282/294ENGINE INFO: CHEVY SMALL BLOCK V8 305-350 CU.IN. 1988-UPAPPLICATION: SPECIAL REMARKS: HYDRAULIC ROLLERPRODUCT USE: STREET/STRIPhttp://iskycams.com/ART/dot_dkgray.gifRPM RANGE: 3000-7000Valve lift is calculated with zero lash and rocker ratio of 1.5INTAKE TIMING DURATION: 282deg.OPEN: 31BEFORE TDCCLOSE: 71AFTER BDCCAM LIFT: .353"VALVE LIFT: .530"VALVE LASH: .HOT.COLDhttp://iskycams.com/ART/timingdiagram.gifEXHAUST TIMING DURATION: 294deg.OPEN: 77BEFORE BDCCLOSE: 37AFTER TDCCAM LIFT: .367"VALVE LIFT: .550"VALVE LASH: .HOT.COLD LOBE CENTER: 110 deg.OVERLAP: 68 deg.CAM ADVANCE: 0 deg.THE ABOVE TIMING IS CHECKED AT .020(OPEN) LIFTER RISE.020(CLOSE)http://iskycams.com/ART/dot_dkgray.gifThe following timing is taken at .050" lifter rise and gives a more accurate determination of camshaft position.INTAKE DURATION: 234deg.OPEN: 7BEFORE TDCCLOSE: 47AFTER BDCEXHAUST DURATION: 246deg.OPEN: 53BEFORE BDCCLOSE: 13AFTER TDChttp://iskycams.com/ART/dot_dkgray.gifRECOMMENDED ISKY CAM KIT PARTS AND SETUP INFORMATION LIFTERS: USE STOCKLIFTER TYPE: HYDRAULIC ROLLERSPRING: 6105TYPE: dual W/DAMPERDIA.: 1.430"RATE: 330 lbs per inchINSTALLED HEIGHT: 1.812"SEAT PRESSURE: 135 lbsOPEN PRESSURE: 315 lbsCOIL BIND: 1.120"SPRING SHIMS: # 2STEEL RETAINERS: 507-STATITANIUM RETAINERS: 60-TIPUSHRODS: 203-HG-.460"TYPE: heat treated non-adjLENGTH: 7.200"DIA.: 5/16"ROCKER ARMS: 204TYPE: rollerRATIO: 1.5VALVE LOCKS: VL-32VALVE LOCKS: VL-32REV KIT: home | what's new | tech info | news | catalog | apparel | about | contact © 2002 Isky Racing Cams. All rights reserved. |
yeah hey thanks for the helpful advice!
This is the cam I used in my 69 camaro with a 406 howards cam part #110265-10 works good what ever cam you use you will need more stall converter :) nice car
| All times are GMT -8. The time now is 02:36 PM. |
