-   -   dana 60 ? (https://www.racingjunk.com/forums/showthread.php?t=28505)
rich970 07-25-2010 01:02 PM
dana 60 ?
i broke my rear end gears a set of 4.88 8620 material. i think the pinion nut came loose. now i need a new set. i have had the 8620 in there for years no problem. do i stick with that or change to the pro gear set ? thanks Rich
traysvega 07-25-2010 02:39 PM
Whats the car weigh,how fast is it? 60 foot?.....4 years is pretty good if you've gotten 200 plus passes.I also run a solid pinion spacer on all the rears I've built.Hard launches can sometimes cause the crush sleeve to crush alittle on it own and then the pinion nuts loose.Some people then try and tighten it only cause more damage as the pinion bearing preload has changed. Also pro gears will wear and break and usually last about 200 passes. I run 8620 gears.their cheaper,and last longer for my combo.
rich970 07-25-2010 03:41 PM
2800 lbs best 1.21 60ft 1/4 8.63 153.4 mph. g force 4 speed . my pinion is shimed no crush collar. i think i am going with the 8620.
