-   -   Dragster front tires? (https://www.racingjunk.com/forums/showthread.php?t=28701)
kwkracing 08-23-2010 10:43 AM
Does anyone use a tube in a front dragster tire? I believe they are good year 17 x 2.25. They have about 20 passes on them, every time the car sits for a day or two, they are flat.
suicidebomb 08-23-2010 11:28 AM
I run tubes in mine, same size tires.
ccperf721p 08-23-2010 11:31 AM
I don't run tubes or know anybody that does in dragster fronts. The trick I was taught was to rub a little palmolive dish soap inside before mounting them up. Mine will hold air for months since I started doing that.
hammertime 08-23-2010 12:35 PM
for sure no tubes, go do a search on the www about tubes blowing out and dragsters wrecking.
kwkracing 08-23-2010 01:29 PM
Any other advise on getting them to quit leaking? Tonight i might try to take them off and put in water and see where they are leaking? They look to be mounted good. Thanks
hammertime 08-23-2010 02:06 PM
Spray some soapy water around the bead and see where its leaking. Some use a bead sealer on them, I've always just soaped the fronts and no issues.
kwkracing 08-23-2010 03:13 PM
How much air psi should i be running? its a 280" hardtail
suicidebomb 08-23-2010 03:38 PM
I'll be taking mine out.
hammertime 08-23-2010 05:18 PM
I run 32lbs in my fronts.
zipper06 08-23-2010 06:18 PM
X2 on the dish soap, works well with tubeless slicks also, just take a paint brush and paint the insides before mounting and balancing, put a little extra air in them for a couple days. Usually they'll never leak unless you run over something, then they are a bitch to patch.
