street stock running hot?
I have a dirt car with a .060" over 350, 450 cam, after about ten minutes the temp is pushing 200 deg. new motor,new tripple pass radiator, custom fan box, 30% reduction pulleies. Timming 4 deg. advanced Can anyone help me cool this thing down?
Are you running a restrictor in thermostat housing?
Re: street stock running hot?
running hot
I seen this before. Ended up being the wrong head gaskets.
you seem to have another issue here with incorrect timing or you dont know what u are setting it at. A performance sbc will not run at zero or 4 degrees base timing. Do your headers glow orange when you run the car at night?
what is your total advance? Did you varify TDC on your pointer (with a degree wheel)when you put it together? I bet that thing gets in it's own way coming out of the corner...
| All times are GMT -8. The time now is 08:29 AM. |
