-   -   Pump gas in a SD 421 engine? (https://www.racingjunk.com/forums/showthread.php?t=28798)
chomama1 09-06-2010 06:08 AM
I am looking real hard at a 62 421 Catalina, ad 1969201, and I went over and heard it run and talked to the guy that built it. The engine is brand new built and is an old 4-bolt 421, this is a pro street car. They fired it up and it is a bad boy, looks and sounds like one of the old B/FX cars. It is supposed to be a 305 duration cam with 11 to 1 compression. I don't want to have to drive 60 miles to the nearest drag strip to get racing fuel for this thing and I just wonder if these octane boosters that you get at the auto parts stores is any good. Most of the stuff I read on the internet about these boosters is from guys who use it in their new BMW, totally different car than what I am looking at. I just want to drive this thing two or three times a month. Any advice?? Thanks.
Rudy
cepx111 09-06-2010 10:59 PM
11-1 is right at the cut off for pump gas, I have run pump gas in a 11-1 motor brielfy but I wouldnt advise it.
What I did most of the time was use a mixture of race gas and pump gas.
And no......
Them octane boosters u get at your local parts house do nothing >pure snake oil :wink:
Now if live close to a small airport or a crop duster airport you might be able to get your hands on some av gas.
Goodluck with that pontiac>Cp
JEFF69Z28 09-07-2010 11:33 AM
And no......
x2,use vp 110 and mix it with 92 street fuel.
nan 10-18-2010 05:17 PM
421
Go to E85
kwkracing 10-18-2010 05:28 PM
Buy a 55 gallon drum of good fuel and keep filling her up!
If the timing is set correct and the car has a good working cooling system you should be able to run pump gas 93 octane.
The other thing to look out for is how they calculated 11 to 1.
