car won/t shut off
68 mustang 302 dist. has points changed the alt. car shut off 3 times after that but now won/t shut off with key thanks brad
sloppy ignition switch? the tabs would break off on the back of the ignition cylinder and would engage to start but not disengage to turn off the power...
if you went to a different type alternator you will have to put a diode in the ign wire going to alt
| All times are GMT -8. The time now is 03:45 AM. |
