alky carb
will a 750 holley alky carb work on a 13 to 1 sbc 383 drag car want to know is it to small or not thanks.
To be exact we need to know what compression, what head design and what rpm your planning on turning it..... It depends how much air u are able to flow.
generally a 750 would work fine on a 383 |
it's a 13 to 1 compression motor the heads are pro action 235 cc 208-160 valves i'm turning the motor around 7200. 4.71 pro gears 28x10.5x15 slicks. 1.76 powerglide.
| All times are GMT -8. The time now is 07:38 PM. |
