18 Degree Intake vs 23 Degree
I'm rebuilding my sbc race engine from the ground up. I will be replacing the heads, intake, valve train, etc. Would going to a 18degree top end make sense? I'm shooting for 700hp.
With the right components you can get 700hp from a 23 deg motor.
TS1955 |
But not as easy as from a 18° motor. We have a 406 that made 705hp with 23° heads and it has had quite a bit of port work on the heads and intake, 15-1 compression on alcohol, with a pretty aggressive cam.
Curtis |
If the dollars are basically the same to buy a new top end, I would think the 18degree is the way to go.
If you are already planning on spending the money, might want to consider a 15 degree setup.
Don't the 12,15 and 18 degree heads use the same intake and exhaust.
700 HP is easy with either 23 degree or 18 degree |
700 HP is easy with either 23 degree or 18 degree Carb to pan. JMO Zip. |
700 HP is easy with either 23 degree or 18 degree Curtis |
Pretty much decided to go the 15/18 route. Not being totally sure what I need to look for other than heads and intake, what else special do I need to look for?
| All times are GMT -8. The time now is 08:45 AM. |
