-   -   Replacing Dipstick Tube (https://www.racingjunk.com/forums/showthread.php?t=29017)
jreiley 10-14-2010 05:29 AM
I know this is a really non-exciting question but the fact is I had to remove the old dipstick tube from my sbc, in the car, and now I am having a super hard time putting in a new one. Any secrets and are there different diameter tubes? Thanks.
JEFF69Z28 10-14-2010 08:20 AM
TRYING SANDING AWAY SOME OF THE METAL AND PUT SOME OIL ON IT WHEN YOU PUT IT BACK IN,ALSO YOU MIGHT HAVE TO TAP IT A LITTLE TO MOVE IT.USE WOOD TO TAP IT IN.
mep 10-14-2010 06:46 PM
dipstick tube
Try tapering the end with a bench grinder, but leave the area under the ring almost full diameter. I found that the open end of a combo wrench works well to tap into the fill hole without distorting the tube. Worked for me. Good Luck. Mike P.
