-   -   Tire Pressure Gauge (https://www.racingjunk.com/forums/showthread.php?t=29135)
jreiley 11-01-2010 01:17 PM
Tire Pressure Gauge
This may seem trivial, but I need a GOOD tire inflation tool with a accurate gauge that also can control the air being added or released. I've look at several and none really do the job. Anybody that knows of a good one, let me know.
fla1976 11-01-2010 01:36 PM
If you are looking for an accurate gauge, this is a 0.5% of full scale from 0 to 12 psig. You should be able to purchase through the manufacturer. I have calibrated a few of them and they are an accurate gauge. You would be able to connect it to a connector that has a Schraeder valve to bleed pressure.
http://www.gmptools.com/nf/77170.htm
