-   -   OIL PSI AT END OF 1/4 MILE (https://www.racingjunk.com/forums/showthread.php?t=29140)
JEFF69Z28 11-02-2010 05:54 AM
LAST PASS I LOOKED DOWN AT THE OIL PSI GAUGE AND AT FULL THROTTLE IT WAS 10-20 PSI WHEN I LEFT OFF THE THROTTLE IT WAS BOUNCING AROUND.I THEN TURNED THE MOTOR OFF WAITED ABOUT 10 MINUTES,STARTED IT BACK UP PSI WAS 50 PSI,I THEN CHECKED THE OIL IT WAS LOW SO I ADDED 2 QUARTS RACED IT AGAIN AND THE SAMETHING HAPPENED.I THEN PARKED THE CAR.DOES ANYONE HAVE ANY IDEAS OR IS THIS NORMAL,PSI IS USALLY 60-70 PSI AT IDLE.
mytmouz 11-02-2010 06:01 AM
Changed the oil lately?
JEFF69Z28 11-02-2010 07:05 AM
NO,10 PASSES SINCE I LAST CHANGED IT.
bbchevy 11-02-2010 07:11 AM
O/Press
WELL?
If I just Changed the Oil 10 Passes ago?And you had to ADD 2QTS to get Oil Pressure,Pull off the Pan,and You will More than Likely find the Pump Pick-Up laying in the Pan!
Or,Maybe Check the FILTER for FINDS?
Later
G 8)
JEFF69Z28 11-02-2010 08:56 AM
Re: O/Press
WELL?
Later
G 8)
Thats what i was thinking.
JEFF69Z28 11-02-2010 09:01 AM
If the pickup came off how much damage do you think is done?seeing how i ran again after said find.could air be trapped in the oil line?
kwkracing 11-02-2010 09:46 AM
Are u burning alcohol for your fuel?
JEFF69Z28 11-03-2010 02:51 AM
no alcohol,vp 110
blowninjected540 11-03-2010 04:16 AM
What oil filter are you running ?
JEFF69Z28 11-03-2010 04:18 AM
fram racing filter cant remember the number.
