-   -   spark plugs (https://www.racingjunk.com/forums/showthread.php?t=29215)
my9secskylark 11-12-2010 04:03 AM
spark plugs
I am curious to find out what is the best spark plug to run in a n/a 563 cubic inch big block Chevy that runs on methanol. The motor has dart pro 2 heads and has around 14-1 compression. I am running a 1050 dominator. I am just curious what everyone is running for spark plugs and why. What is the best way to determine the correct plug. I would like to try the e3 plugs but have no clue which one to run. Any suggestions will help. Thanks
markdunlap 11-12-2010 03:28 PM
spark plug
E3 is not for racing in my opinion, just street cars and maybe just a fad?
NGK plugs work well and can be read because of their plating that changes color with heat.
R-5671A-8 or 9 will work in alot of instances. I like 8 for gas and 9 for alky. Every engine combination is different though.
my9secskylark 11-13-2010 05:58 AM
I have ran the ngk and will stick with them. I just didnt know if anyone tried the e3. Thanks
johnracer 11-13-2010 06:38 AM
In my opinion, you won't find any magic in trick-of-the-week spark plugs. They're just gimmics designed to sell spark plugs. Stick with what you know works.....again, just my opinion.
Johnny
my9secskylark 11-13-2010 01:18 PM
That's about how I feel. They make stuff so promising. Thanks
lanham 01-29-2011 06:31 AM
I use NGK spark plugs.
fast75vega 01-29-2011 07:17 AM
Re: spark plug
i second that :wink: NGK's are the only plugs to run.... i actually tried the accell U-grove plugs before and they worked very well.... very short and great for headers......just hard to find .... NGK's are everywhere :D
