-   GM LS engine talk (https://www.racingjunk.com/forums/forumdisplay.php?f=21)
-   -   From flexplate to Flywheel (https://www.racingjunk.com/forums/showthread.php?t=29243)
chevyfireball 11-19-2010 12:55 PM
My bud has bought a 94 Corvette engine. Its a 350ci with one piece rear seal. Currently has a counterweighted flexplate on it but he wants to put a flywheel on for his manual gearbox.
Are all these engines external balancing and can he just chuck on a counterweighted flywheel without doing anything else?
fla1976 11-19-2010 01:47 PM
According to Summitt, the OEM harmonic balancer is internally balanced. So, the flywheel should be internally balanced.
http://www.summitracing.com/search/P...nic-Balancers/
kwkracing 11-29-2010 09:32 PM
gm stock one piece cranks use a weight on the flywheel or flexplate, bc they machined the counterweight off when they made it one piece, Round on the end. Theres a flywheel for it, but there hard to find
