-   -   bbc want start ? (https://www.racingjunk.com/forums/showthread.php?t=29335)
clwarters 12-03-2010 03:10 AM
bbc want start ?
my brother installed a 454 drive train from a 90 sport 454 chev truck into a 70 ss chevelle . everything ran fine for a about a year . just replaced the intake gasket . now we can not start the eng. checked the timming many times piston #2 top comp disturb point strait to it .went got new cap, coil, plugs, wires ? GOT GAS to carb - GOT FIRE to plugs . i dont get it , thing will not hit a lick rockers move so chain good and the darn thing ran fine when he pulled the intake has anyone got any help on things to try thanks ,
JEFF69Z28 12-03-2010 05:09 AM
MAKE SURE NUMBER 1 PISTON IS UP ON COMPRESSION STROKE BOTH VALVES CLOSED.POINT DIST.ROTOR BUTTON AT NUMBER ONE CYLINDER AND INSERT,YOU MIGHT HAVE TO MOVE THE OIL PUMP DRIVE A FEW TIMES TO GET IT RIGHT
TS1955 12-03-2010 05:24 AM
X2...Time it off of # 1 cylinder!
TS1955
clwarters 12-03-2010 02:33 PM
bbc want start ?
thanks the problem seem to be a ground wire , ahd he put the wrong intake gasket on , running fine now :lol:
