Ford 9 in ?????
How much oil should it take ? and what kind in drag car runs 10 seconds 130 mph. Thanks in advance Oh yea do I get limited slip oil??
how much oil wel enogh to fill it and limited slip if you have a limited slip or posi each aftermarket design is little different and amounts will very
5 pints. Just fill to the top of the fill hole if it has the original filler plug. If you have traction-loc then call it 2 quarts plus a tube of friction modifier.
| All times are GMT -8. The time now is 10:44 AM. |
