what type of transfer case does my silverado 1500 have in it
its a 2000
Several possibilities. Most likely a NewProcess/Venture. There should be a round metal disc bolted to the back of it with all the info.....
Johnny |
there is no tag onn it so im wondern which one it is
Push button or lever?
push button
Should be a NVG-246....
Johnny |
ok i have one out of a 2003 1500 but the wireing isnt the same is there anyway i can make it work?
What's different? The connectors or ? If memory serves, the only connectors are the encoder (shift motor), a switch on top that locks in the front axle, a syncro clutch connector at the rear, and a front & rear speed sensor. Could you swap those components to the newer t/c and plug in your existing wiring? I think they all unbolt or screw out except for the syncro clutch. You might have to change the connector on that.
Hope this helps, Johnny |
the one out of the 2000 has like 5 plugs on it i think and the 2003 only has three
does any one knows what all year transfercases will fit my 2000 chevy 1500? thanks
| All times are GMT -8. The time now is 07:38 PM. |
