wtb centerline prostock rims
wtb centerline prostock rims,front runners or a single 7inch rim or will take a full set must be 5 stud gm or ford just pm me with what you have thanks
You'll have better luck if you check in the classified section.
you can without difficulty get entry to facts about “Chase Bank payoff Address Phone number with the aid of following this article at last.
Originally Posted by hothgholden
(Post 237338)
wtb centerline prostock rims,front runners Speed Test or a single 7inch rim or will take a full set must be 5 stud gm or ford just pm me with what you have thanks
I have the opportunity to buy some Vintage old school Centerline Drag wheels locally. I will be looking at the this afternoon. I just want to make sure they are indeed true Centerlines and not the many knockoff versions. I have identified the fronts that have Center Line stamped into them, but can't confirm on the rears. Does anyone here have information for best identifying Centerlines?
(Post 237338)
| All times are GMT -8. The time now is 09:04 AM. |
