Can anyone help with a sbc build up
I have a 350 block, steel crank and a set of eagle rods, 5.7. I have had some bad BBC before but not really messed with SBC too much. Want to be able to put a non-lightened up S10 in the low 10s. 488 gears 550 converter. I still need to buy the rest of the stuff, heads, cam( would like to stay with a solid... mechanical) ,pistons, etc... Can you guys help me out from here...Thanks alot, Rob...
stroke it punch it .030 min order scat or eagle rotating assembly if street driven too not much over a 9:1 cr dart makes a top end kit with pro 1 heads and intake or eldelbrock has one that also includes matched cam summit part #edl-2096 460hp kit
Plan on a roller cam and REAL good heads and intake, and you will need to spin it a bit. I would call Chad for heads if you need to stay with 23˚ heads. Something like these.
http://1320techtalk.com/viewtopic.php?t=2053 |
I know of a Chevelle with an 'extreme' RPM small block in it !
A tad spendy though :shock: :shock: |
Re: Can anyone help with a sbc build up
290B6
| All times are GMT -8. The time now is 03:05 AM. |
