lashing roller rockers?
I have a 1981 camaro wiyh 454 60 over to a 468 I think. With roller set up. Have made 15 or so passes at the track. car still runs good . Ive changed the oil and plugs and plugwires and thats all the mant, Ive done to the motor. My Q, is do I need to ck the lashing on my lifters once in awhile and if so what do i set them at? Imnot a mech. but tryiny to learn as I go Thanks Jack.
mechanical or hydralic
ooked up paper work says hydraulic
normally hydraulics are ok but i know circle track guys that check every weekend and i know drag guys that check once a season i know that dont help. i guess id say if you feel better checking before each weekend racing do so
Thanks .
Leave them alone
Originally Posted by kwkracing
Leave them alone
Now if I heard one clicking, then that would be worthy of a looky loo. Cp |
On a side note:
I ran hydralic flat tappet cams for years before I ever went to solid rollers. I never re-checked the preload once I set it and I ran mine on the loose side, just a tick over a 1/4 turn....... I know we're talking about a hydralic rollers here but preload is preload. Cp |
| All times are GMT -8. The time now is 08:36 PM. |
