-   -   68 camaro (https://www.racingjunk.com/forums/showthread.php?t=29625)
matt1234 01-16-2011 07:55 PM
68 camaro
the engine runs great but no headlights dome light or dash lights. All my fuses are good. Can't figure it out
dragonmaster093 01-16-2011 08:32 PM
distribution block
johnracer 01-17-2011 02:50 AM
It seems to me that the early Camaro's had fuse links at the horn relay. Might check there and make sure they're clean and tight. I think the relay is on the radiator support next to the voltage regulator....
Johnny
fast75vega 01-17-2011 05:29 AM
check the head light switch it self... cause everything you listed is routed and controlled by that :) they are pretty cheap to buy and then just unplug the old and plug in the new...... i had a few chevy's do this to me
