Intake gasket
When a Intake gasket blows out ,does it suck in or blow out? I am talking more about the front or back. Thanks in advance
I have seen either direction :!: :!:
Mark |
A real violent backfire will blow them outward. Long decelerations with a tightly sealed cylinder can suck 'em inward. |
Originally Posted by DrivingMissDD
A real violent backfire will blow them outward. |
With proper crush and PARALLEL surfaces and a SKIM of sealer that is allowed to set before use, this should never happen. If the surfaces are NOT parallel, the gasket will have more tendency to squeeze out the 'big' end whether going outbound or inbound.
IT WOULD BLOW SOME OIL OUT,, NOT SUCK IN AIR,, BECAUSE OF THE INTERNAL PRESSURE,, pretty sure..
You are right ''bigray'' it would leak oil or at least everyone i have seen did :!: :!:
Mark |
If you are running a vacuum pump, it will suck in. If not, the crankcase pressure will cause it to push oill out. The only thing I use on the ends to seal the intake after make sure it and the block are clean of any oil/water is Right Stuff from peratex.
| All times are GMT -8. The time now is 04:47 PM. |
