-   -   pro systems sv1 carb question (https://www.racingjunk.com/forums/showthread.php?t=29692)
taps 01-24-2011 05:15 AM
anyone got any input on the new pro systems sv1 carb?thinking about getting a pair for my 871 blown 509.
jmarksdragster 01-24-2011 09:42 AM
My suggestion would be to get a pair of custom carbs from someone like BLP, APD, Braswell...
bbchevy 01-24-2011 11:00 AM
Re: pro systems sv1 carb question
Ever Heard of ENDELE Fuel INJECTION?You'll Throw ROCKS at them Carbs after having INJECTION.............!
Later
G 8)
taps 01-24-2011 11:11 AM
yes i have heard of fuel injection,i just dont want to have to change to front mount cell,mechanical pump, primer to start etc.
hammertime 01-24-2011 01:15 PM
You looking for gas or alky carbs ?
taps 01-24-2011 01:45 PM
it is a race gas set up.871 blown 509 in tube chassis beretta.
blowninjected540 01-25-2011 03:01 AM
Once you did switch you'll kick yourself why you didn't do it before' so much easier and still after the switch it will be cheaper then buying 2 carbs. Enderle sells a primer kit, no need for 2 people to start the car. JMO. Been there and after I switched to the birdcatcher so much more fun and less screwing around. Good Luck W/ them carbs.
